▫️ Key Features
RG-02
  • The RG-02 is an indoor LoRaWAN gateway that supports Semtech packet forwarders and LoRaWAN base station functions, while being compatible with the standard LoRaWAN protocol. It adopts a mainstream LoRa modulation and demodulation chip solution (SX1302 + 2*1250) and supports 10 programmable parallel demodulation paths.
  • The gateway supports WiFi, Ethernet, and 3G/4G cellular network access methods, enabling convenient deployment in various application scenarios. It comes pre-configured with multiple standard LoRaWAN frequency band options, adapting to different countries and regions. Additionally, it supports user-defined frequency bands for building private LoRa networks.
  • The RG-02 can communicate with ABP LoRaWAN end nodes without a LoRaWAN server. Its lightweight deployment makes it easy for system integrators to directly connect it to existing IoT applications without the need to set up a LoRaWAN server or use third-party LoRaWAN services.
▫️ Technical Highlights
  • Web GUI and SSH management via LAN or WiFi.
  • Emulates 49x LoRa demodulators.
  • Maximum transmit power of +27 dBm.
  • Pre-configured with multiple LoRaWAN regional settings and supports custom frequency points:
    • High-frequency version (EU868, IN865, RU864, KZ869), low-frequency version (CN470).
  • Semtech packet forwarder.
  • Multiple network access methods:
    • WiFi IEEE 802.11 b/g/n.
    • Ethernet 10/100M.
    • Cellular network.
ModuleSpecification
RG-02(Low-frequency version)View
RG-02(High-frequency version)View
3. Guide
  • The RG-02 gateway connects to the TTN platform to control multiple LoRaWAN module nodes.:View
  • The RG-02 gateway integrates network configuration, enabling MQTT configuration to connect to the network server and facilitating data intercommunication.:View
4. FAQ
