▫️ Key Features
Ra-05U
  • Ra-05U is a 2.4GHz RF transceiver module developed by Shenzhen Ai-Thinker Co., Ltd. It features the SX1281 RF chip from Semtech as its core processor, supporting multiple modulation methods such as LoRa, FLRC, GFSK, and being compatible with Bluetooth protocols.
  • This module is a pure RF transceiver that requires an MCU for driving or a dedicated SPI debugging tool. LoRa's direct-sequence spread spectrum technology enables longer communication distances, with a wider power spectrum and strong anti-interference capabilities. The module incorporates a hardware FEC (Forward Error Correction) algorithm, which offers high coding efficiency and robust error correction. It can actively correct corrupted data packets under 突发干扰 (burst interference), significantly improving reliability and transmission range.
  • The module boasts high transmit power and receive sensitivity, delivering excellent performance in spectral characteristics, harmonic spurs, and channel crosstalk. Additionally, it features a compact size and strong package compatibility.
▫️ Technical Highlights
  • Supports the license-free ISM 2.4GHz band.
  • Supports data rates from 1 kbps to 2 Mbps.
  • Maximum transmit power of 12.5 dBm, adjustable in multiple software-controlled steps.
  • Receive sensitivity (per chip datasheet) up to -132 dBm in LoRa mode.
  • Operates from 1.8 to 3.6 VDC; optimal performance is ensured with a supply voltage above 3.3 V.
  • Designed to industrial standards, supporting long-term operation from -40°C to 85°C.
  • Supports multiple modulation modes (GFSK Mode, FLRC Mode, LoRa Mode).
  • Exceptional anti-blocking characteristics.
  • Antenna interface uses an IPEX connector, allowing versatile antenna selection.
Ra-05ViewDownload
ModuleCertificateLink
Ra-05CE (RED)View
Ra-05FCCView
To learn more
4. Compliance & Testing
  • Ra-05U Power Consumption Test Report:View
  • Ra-05U Hardware Reliability Test Report:View
