▫️ Key Features
Ra-08(H)
  • The Ra-08(H) module is a LoRaWAN module jointly developed by Ai-Thinker Co., Ltd. and ASR (Advanced Signal Research). The module uses the ASR6601CB chip, with 128 KB Flash, 16 KB SRAM, and a 32-bit 48 MHz ARM Cortex-M4 core. The Ra-08(H) module comes pre-installed with AT firmware, allowing direct use to connect to LoRaWAN gateways.
Ra-08-P/Ra-08H-P
  • The Ra-08-P/Ra-08H-P modules are LoRaWAN modules developed by Ai-Thinker, supporting high-power configurations for ultra-long-distance communication, ultra-low power consumption, high sensitivity, and high cost-effectiveness.
▫️ Technical Highlights
  • Excellent anti-interference capability, capable of normal operation in complex interference environments
  • Minimum receiving sensitivity: -137dBm (SF=12/BW=125KHz)
  • Maximum transmit power: +21dBm
  • Operating frequency: (Ra-07/08/09/09-DTU) 410MHz~525MHz (default), (Ra-07H/08H/09H) 803MHz~930MHz (default)
  • Power supply voltage: 3.3V (Ra-07/08/09/09/07H/08H/09H), 12V (Ra-09-DTU)
  • Transmit operating current: 107mA (full load power consumption)
  • Receive operating current: 6mA
ModuleDatasheetsChip DatasheetPCB FootprintsSchematics
Ra-08ViewViewDownloadDownload
Ra-08HViewViewDownloadDownload
Ra-08-PView-DownloadDownload
Ra-08H-PView-DownloadDownload
Ra-08-KitView--Download
Ra-08H-KitView--Download
3. Firmware Management
3.1 Non-amplified module firmware
ModuleFirmware BuildFirmware DescriptionVersionDownload LinkAT Command Reference
Ra-08⭐1950号LoRaWAN- AS923常规固件V4.18_P1.4.0DownloadView
Ra-08⭐1951号LoRaWAN- AU915常规固件V4.18_P1.4.0DownloadView
Ra-08⭐1955号LoRaWAN- CN470常规固件V4.18_P1.4.0DownloadView
Ra-08H⭐1956号LoRaWAN EU868常规固件V4.18_P1.4.0DownloadView
Ra-08H⭐1957号LoRaWAN IN865常规固件V4.18_P1.4.0DownloadView
Ra-08H⭐1958号LoRaWAN US915常规固件V4.18_P1.4.0DownloadView
3.1 Amplified module firmware
Ra-08-P⭐2944号LoRaWAN CN470常规固件V4.18_P1.7.3DownloadView
Ra-08H-P⭐2953号LoRaWAN US915常规固件V4.18_P1.7.3DownloadView
Ra-08H-P⭐2898号LoRaWAN EU868常规固件V4.18_P1.7.3DownloadView
Ra-08H-P⭐2954号LoRaWAN IN865常规固件V4.18_P1.7.3DownloadView
Ra-08H-P⭐2956号LoRaWAN AS923常规固件V4.18_P1.7.3DownloadView
Ra-08H-P⭐2957号LoRaWAN AU915常规固件V4.18_P1.7.3DownloadView
4. Compliance & Testing
ModuleReport
Ra-08View
Ra-08-PView
Ra-08HView
Ra-08H-PView
ModuleReport
Ra-08H-PView
Ra-08HView
Ra-08-PView
Ra-08View
ModuleCertificateLink
Ra-08-PCE (RED)View
Ra-08-PFCCView
Ra-08H-PCE (RED)View
Ra-08H-PFCCView
Ra-08HCE (RED)View
Ra-08HFCCView
Ra-08CE (RED)View
Ra-08FCCView
